Ga door naar hoofdinhoud
Garmin Fenix 3 GPS Antenna Replacement
Wat je nodig hebt
  1. Garmin Fenix 3 GPS Antenna Replacement, Display Assembly: stap 1, afbeelding 1 van 2 Garmin Fenix 3 GPS Antenna Replacement, Display Assembly: stap 1, afbeelding 2 van 2
    • Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
  2. Garmin Fenix 3 GPS Antenna Replacement: stap 2, afbeelding 1 van 1
    • Carefully lift the face off the watch base.
    • Do not yank the face. A ribbon connector connects the face and the motherboard, and yanking could result in damage to the motherboard or ribbon.
  3. Garmin Fenix 3 GPS Antenna Replacement: stap 3, afbeelding 1 van 1
    • Use a spudger to lift up and free the screen ribbon cable's press-fit connector from the motherboard.
  4. Garmin Fenix 3 GPS Antenna Replacement: stap 4, afbeelding 1 van 1
    • Set the watch face aside.
  5. Garmin Fenix 3 GPS Antenna Replacement, GPS Antenna: stap 5, afbeelding 1 van 1
    • Locate the antenna, which is located on the motherboard.
  6. Garmin Fenix 3 GPS Antenna Replacement: stap 6, afbeelding 1 van 1
    • Carefully remove the antenna, and set it aside.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
8 opmerkingen
Hi, where did you get a replacement Antenna?`I have a Fenix 3 with no GPS reception at all..
Regards, Nico
Nico Baumgartner - Antwoord
Same as you…
X PuyA -
Hi, where did you get a replacement Antenna? I have a Fenix 3 with no GPS reception at all..
Regards, Dusan
dusan.kosobud - Antwoord
Hi did you find gps antenna
Abdessamad Faroque - Antwoord
Could you please add a link where to buy the antenna?
marco475 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 46
Altijd: 5,249
