Inleiding
If your Garmin Edge 1000 has started to malfunction, its motherboard may need replacement. In this guide, you will learn how to replace the Garmin Edge 1000 motherboard. The motherboard is the part of the computer that allows communication between all of the parts of the computer so be careful replacing this part, as it the most crucial part of a computer.
Wat je nodig hebt
Hold the device front side down. Remove the eight T6 Torx screws along the backside of the device.
Pull the front side of the device apart from the back side.
4 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Bonjour
Je cherche la référence du connecteur qui relie l’écran LCD à la carte mère
Il s’agit du connecteur FCP de 50 pins.
Pouvez vous me dire ou je pourrais trouver cette pièce?
En vous remerciant par avance
How about software?
