Ga door naar hoofdinhoud
Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement
Wat je nodig hebt
  1. Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Back Cover: stap 1, afbeelding 1 van 2 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Be sure the device is properly powered all the way off before starting the replacement.
    • Hold the device front side down. Remove the eight T6 Torx screws along the backside of the device.
    • Pull the front side of the device apart from the back side.
  2. Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement: stap 2, afbeelding 1 van 2 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement: stap 2, afbeelding 2 van 2
    • Disconnect the bronze SIM card flex cable from the motherboard with your finger.
    • Disconnect the battery cord to completely separate the front cover from the back cover of the device with your finger.
  3. Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Micro SD+SIM Card Tray Holder Slot Flex Cable: stap 3, afbeelding 1 van 3 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Micro SD+SIM Card Tray Holder Slot Flex Cable: stap 3, afbeelding 2 van 3 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Micro SD+SIM Card Tray Holder Slot Flex Cable: stap 3, afbeelding 3 van 3
    • Take a metal spudger and use force to push the micro USB port out of its socket on the other end.
    • Use the metal spudger once again to use force and push the SIM card port out of its socket. This will allow you to remove this piece entirely and insert a new charging port into the same place.
Conclusie
4 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 1,559
