Inleiding
If there is an issue with your Garmin 1000 Edge (M/N F4ACGQ00) mount, use this guide to replace the back cover of your unit.
The back cover houses the device’s SIM card and battery as well. This guide can be used to gain access to these components as needed.
Wat je nodig hebt
Hold the device front side down. Remove the eight T6 Torx screws along the backside of the device.
Pull the front side of the device apart from the back side.
Één andere persoon heeft deze handleiding voltooid.
