Ga door naar hoofdinhoud
Garmin Dezl 770LMT Speaker Replacement
Wat je nodig hebt
  1. Garmin Dezl 770LMT Speaker Replacement, Back Panel Removal: stap 1, afbeelding 1 van 2 Garmin Dezl 770LMT Speaker Replacement, Back Panel Removal: stap 1, afbeelding 2 van 2
    • Turn the device screen down and using the screwdriver remove all eight screws from the back plate.
  2. Garmin Dezl 770LMT Speaker Replacement: stap 2, afbeelding 1 van 1
    • Place a nylon spudger in the seam between the front and back panel and carefully lift around the edge of the device.
  3. Garmin Dezl 770LMT Speaker Replacement: stap 3, afbeelding 1 van 1
    • Use the spudger to pry apart the screen from all around the device.
    • Gently lift the screen so not to disconnect the ribbon attaching the screen to the motherboard.
  4. Garmin Dezl 770LMT Speaker Replacement, Speaker: stap 4, afbeelding 1 van 2 Garmin Dezl 770LMT Speaker Replacement, Speaker: stap 4, afbeelding 2 van 2
    • Using the sharp side of the spudger, scrape away the adhesive surrounding the speaker.
    • Slide the spudger beneath the speaker and pull it away from the case.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  5. Garmin Dezl 770LMT Speaker Replacement: stap 5, afbeelding 1 van 2 Garmin Dezl 770LMT Speaker Replacement: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Anti-Static Wrist Strap
    $7.95
    Koop
    • Grasp the wire connecting the motherboard and pull the wares connecting it.
    • Remember to wear an anti-static wrist strap when handling the motherboard.
Conclusie
Francisco Rosado
370 Reputatie
4 handleidingen geschreven
USF Tampa, Team 1-3, Lacy Fall 2016 Lid van USF Tampa, Team 1-3, Lacy Fall 2016
USFT-LACY-F16S1G3
4 Leden
5 handleidingen geschreven
2 opmerkingen
do u know where i can get a replacement speaker
markrushforth65 - Antwoord
Hi where can I buy the speaker, i hardly use my deal 770 lm and speaker gave up.
Noel Borg - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 1,018
