Ga door naar hoofdinhoud
Garmin Dezl 770LMT Battery Replacement
Wat je nodig hebt
  1. Garmin Dezl 770LMT Battery Replacement, Back Panel Removal: stap 1, afbeelding 1 van 2 Garmin Dezl 770LMT Battery Replacement, Back Panel Removal: stap 1, afbeelding 2 van 2
    • Turn the device screen down and using the screwdriver remove all eight screws from the back plate.
  2. Garmin Dezl 770LMT Battery Replacement: stap 2, afbeelding 1 van 1
    • Place a nylon spudger in the seam between the front and back panel and carefully lift around the edge of the device.
  3. Garmin Dezl 770LMT Battery Replacement: stap 3, afbeelding 1 van 1
    • Use the spudger to pry apart the screen from all around the device.
    • Gently lift the screen so not to disconnect the ribbon attaching the screen to the motherboard.
  4. Garmin Dezl 770LMT Battery Replacement, Battery Replacement: stap 4, afbeelding 1 van 3 Garmin Dezl 770LMT Battery Replacement, Battery Replacement: stap 4, afbeelding 2 van 3 Garmin Dezl 770LMT Battery Replacement, Battery Replacement: stap 4, afbeelding 3 van 3
    • Using a metal spudger, carefully pry the battery from the device.
    • The regular black nylon spudger should be used whenever possible, especially around batteries.
    • Before you place the battery back in, make sure to place some double-sided electrical tape to attach it to the case.
  5. Garmin Dezl 770LMT Battery Replacement: stap 5, afbeelding 1 van 2 Garmin Dezl 770LMT Battery Replacement: stap 5, afbeelding 2 van 2
    • Grasp the wire near the mother board and gently lift to detach the battery.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Francisco Rosado
370 Reputatie
4 handleidingen geschreven
USF Tampa, Team 1-3, Lacy Fall 2016 Lid van USF Tampa, Team 1-3, Lacy Fall 2016
USFT-LACY-F16S1G3
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 38
Altijd: 6,107
