Ga door naar hoofdinhoud
Garmin Dezl 760LMT Motherboard Replacement
Wat je nodig hebt
  1. Garmin Dezl 760LMT Motherboard Replacement, Back Panel: stap 1, afbeelding 1 van 2 Garmin Dezl 760LMT Motherboard Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
  2. Garmin Dezl 760LMT Motherboard Replacement: stap 2, afbeelding 1 van 3 Garmin Dezl 760LMT Motherboard Replacement: stap 2, afbeelding 2 van 3 Garmin Dezl 760LMT Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Using a metal spudger, pry the device apart.
    • To recombine them, line up the two halves of the device and press them together.
  3. Garmin Dezl 760LMT Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Turn the device over, laying it on its back with the screen facing upwards.
    • Lift the front panel away from the silver part of the back panel.
    • Make sure not to rip the ribbon cable that is connected to the screen and the motherboard.
  4. Garmin Dezl 760LMT Motherboard Replacement, Screen Ribbon Cable: stap 4, afbeelding 1 van 2 Garmin Dezl 760LMT Motherboard Replacement, Screen Ribbon Cable: stap 4, afbeelding 2 van 2
    • Lift the screen opposite where the "GARMIN" logo is located. Remove the clear tape holding the ribbon cable to the motherboard.
  5. Garmin Dezl 760LMT Motherboard Replacement: stap 5, afbeelding 1 van 2 Garmin Dezl 760LMT Motherboard Replacement: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Anti-Static Wrist Strap
    $7.95
    Koop
    • Find and lift the small grey hinge at the end of the ribbon cable.
    • When handling the motherboard, make sure to wear an anti-static wrist strap.
  6. Garmin Dezl 760LMT Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 2 Garmin Dezl 760LMT Motherboard Replacement, Motherboard: stap 6, afbeelding 2 van 2
    • Using a Torx T5 screwdriver, unscrew the six 5mm screws on the motherboard.
  7. Garmin Dezl 760LMT Motherboard Replacement: stap 7, afbeelding 1 van 3 Garmin Dezl 760LMT Motherboard Replacement: stap 7, afbeelding 2 van 3 Garmin Dezl 760LMT Motherboard Replacement: stap 7, afbeelding 3 van 3
    • Grasp each of the three wires near where it is attached to the motherboard. Lift them upward to detach them.
    • Lift the motherboard from the device.
Conclusie
Ryan Williams
763 Reputatie
6 handleidingen geschreven
USF Tampa, Team 4-2, Passmore Fall 2016 Lid van USF Tampa, Team 4-2, Passmore Fall 2016
USFT-PASSMORE-F16S4G2
4 Leden
2 opmerkingen
i realy appreciate the video but please tell me where can i find buy the motherboard or others parts for my gps rv-760
Thank you
Pierre Delisle
Québec
Canada
Pierre Delisle - Antwoord
Is it possible to buy the ribbon cable from the screen to the mother board, and what’s the procedure to replace it on the display ? Thanks
Kiki B - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 2,834
