Inleiding
This guide will explain how to open your Garmin, detach the battery from the motherboard, and remove the battery from the device safely and quickly.
Wat je nodig hebt
Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
6 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Completely useless as soon as you open the cover the old ribbon rips and you garmin is junk. Don’t waste your money
you have to be more careful with your stuff dude..
