Ga door naar hoofdinhoud
Garmin Dezl 760LMT Battery Replacement
Wat je nodig hebt
  1. Garmin Dezl 760LMT Battery Replacement, Back Panel: stap 1, afbeelding 1 van 2 Garmin Dezl 760LMT Battery Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
  2. Garmin Dezl 760LMT Battery Replacement: stap 2, afbeelding 1 van 3 Garmin Dezl 760LMT Battery Replacement: stap 2, afbeelding 2 van 3 Garmin Dezl 760LMT Battery Replacement: stap 2, afbeelding 3 van 3
    • Using a metal spudger, pry the device apart.
    • To recombine them, line up the two halves of the device and press them together.
  3. Garmin Dezl 760LMT Battery Replacement: stap 3, afbeelding 1 van 1
    • Turn the device over, laying it on its back with the screen facing upwards.
    • Lift the front panel away from the silver part of the back panel.
    • Make sure not to rip the ribbon cable that is connected to the screen and the motherboard.
  4. Garmin Dezl 760LMT Battery Replacement, Battery: stap 4, afbeelding 1 van 2 Garmin Dezl 760LMT Battery Replacement, Battery: stap 4, afbeelding 2 van 2
    • This photo shows the use of a tool that is not ESD safe. Use a nylon spudger to complete this step.
    • Use a nylon spudger to pry the battery from the device.
    • During reassembly, place double-sided electrical tape under the battery before pressing it into its slot.
  5. Garmin Dezl 760LMT Battery Replacement: stap 5, afbeelding 1 van 2 Garmin Dezl 760LMT Battery Replacement: stap 5, afbeelding 2 van 2
    • Grasp the battery wire near the motherboard and lift upward to detach the connector.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Ryan Williams
763 Reputatie
6 handleidingen geschreven
USF Tampa, Team 4-2, Passmore Fall 2016 Lid van USF Tampa, Team 4-2, Passmore Fall 2016
USFT-PASSMORE-F16S4G2
4 Leden
2 opmerkingen
Completely useless as soon as you open the cover the old ribbon rips and you garmin is junk. Don’t waste your money
Pissedoff - Antwoord
you have to be more careful with your stuff dude..
Bealphares Voluptarius -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 5,899
