Ga door naar hoofdinhoud
Inleiding
This guide will walk users through removing the top cover of the Garmin Dash Cam as well as the metal battery frame. Due to the compact nature of this device, this guide is a prerequisite to other guides that require access to the internal components of the device.
Onderdelen
Geen onderdelen opgegeven.
  1. Garmin Dash Cam 20 Internal Assembly, Internal Assembly: stap 1, afbeelding 1 van 2 Garmin Dash Cam 20 Internal Assembly, Internal Assembly: stap 1, afbeelding 2 van 2
    • Be sure to turn off the Dash Cam by pressing the power button.
  2. Garmin Dash Cam 20 Internal Assembly: stap 2, afbeelding 1 van 2 Garmin Dash Cam 20 Internal Assembly: stap 2, afbeelding 2 van 2
    • Rotate the Dash Cam to where the socket faces you.
    • Remove the 9 mm screw using the Torx T6 screwdriver.
  3. Garmin Dash Cam 20 Internal Assembly: stap 3, afbeelding 1 van 2 Garmin Dash Cam 20 Internal Assembly: stap 3, afbeelding 2 van 2
    • Remove the Dash Cam socket piece.
  4. Garmin Dash Cam 20 Internal Assembly: stap 4, afbeelding 1 van 2 Garmin Dash Cam 20 Internal Assembly: stap 4, afbeelding 2 van 2
    • Rotate the Dash Cam to where the product information faces you.
    • Remove the two 5 mm screws using the Torx T5 screwdriver.
  5. Garmin Dash Cam 20 Internal Assembly: stap 5, afbeelding 1 van 3 Garmin Dash Cam 20 Internal Assembly: stap 5, afbeelding 2 van 3 Garmin Dash Cam 20 Internal Assembly: stap 5, afbeelding 3 van 3
    • Remove top case from the bottom case.
    • The compact nature of the casing requires use of the metal spudger for needed leverage.
  6. Garmin Dash Cam 20 Internal Assembly: stap 6, afbeelding 1 van 3 Garmin Dash Cam 20 Internal Assembly: stap 6, afbeelding 2 van 3 Garmin Dash Cam 20 Internal Assembly: stap 6, afbeelding 3 van 3
    • Remove the two 5mm screws using the Torx T5 screwdriver
    • By removing the screws, the metal battery frame will now become free from the rest of the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jesse Hillman
757 Reputatie
5 handleidingen geschreven
USF Tampa, Team 2-1, Cagle Fall 2016 Lid van USF Tampa, Team 2-1, Cagle Fall 2016
USFT-CAGLE-F16S2G1
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 54
