Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Rotate the Dash Cam to where the socket faces you.
Remove the 9 mm screw using the Torx T6 screwdriver.
Rotate the Dash Cam to where the product information faces you.
Remove the two 5 mm screws using the Torx T5 screwdriver.
Remove the two 5mm screws using the Torx T5 screwdriver
Remove the green tape overlying the pin connector with tweezers.
Remove the pin connector using tweezers.
With the the nylon spudger, lift the battery to expose and stretch the glue. Cut the glue residue by gliding the tool from left to right.
3 andere personen hebben deze handleiding voltooid.
3 opmerkingen
An excellent article except for one major problem but, why does iFixIt not sell theses batteries or direct you on where a person could actually buy one? This knowledge is pretty much useless with out a replacement battery to actually use.
Yeah I agree
Thanks for this guide. This gave my Garmin 20 another couple of years! :)
BTW, I was able to buy the battery replacement from Amazon: https://www.amazon.com/gp/product/B07KSR...
