Ga door naar hoofdinhoud
Gamestop G3 Gamecube Left and Right Trigger Replacement
Wat je nodig hebt
  1. Gamestop G3 Gamecube Left and Right Trigger Replacement, Back Panel: stap 1, afbeelding 1 van 3 Gamestop G3 Gamecube Left and Right Trigger Replacement, Back Panel: stap 1, afbeelding 2 van 3 Gamestop G3 Gamecube Left and Right Trigger Replacement, Back Panel: stap 1, afbeelding 3 van 3
    • First, remove the 6 screws in the back panel and pull the back panel off.
    • Separate the halves of the controller. However, be careful when separating due to the little wires that could get mixed up.
  2. Gamestop G3 Gamecube Left and Right Trigger Replacement: stap 2, afbeelding 1 van 3 Gamestop G3 Gamecube Left and Right Trigger Replacement: stap 2, afbeelding 2 van 3 Gamestop G3 Gamecube Left and Right Trigger Replacement: stap 2, afbeelding 3 van 3
    • Next, remove the rumble motor by unscrewing the 2 screws connecting it.
  3. Gamestop G3 Gamecube Left and Right Trigger Replacement: stap 3, afbeelding 1 van 3 Gamestop G3 Gamecube Left and Right Trigger Replacement: stap 3, afbeelding 2 van 3 Gamestop G3 Gamecube Left and Right Trigger Replacement: stap 3, afbeelding 3 van 3
    • Finally remove the screws holding in the right and left triggers. It's easiest to hold the trigger together as shown in the third picture. Remove both the left and right trigger, and then you have successfully removed your back panel.
  4. Gamestop G3 Gamecube Left and Right Trigger Replacement, Left and Right Trigger: stap 4, afbeelding 1 van 2 Gamestop G3 Gamecube Left and Right Trigger Replacement, Left and Right Trigger: stap 4, afbeelding 2 van 2
    • Remove the screws holding the plastic bumper cover in place and remove it.
  5. Gamestop G3 Gamecube Left and Right Trigger Replacement: stap 5, afbeelding 1 van 3 Gamestop G3 Gamecube Left and Right Trigger Replacement: stap 5, afbeelding 2 van 3 Gamestop G3 Gamecube Left and Right Trigger Replacement: stap 5, afbeelding 3 van 3
    • At this point you should be able to remove the bumper along with its spring from the controller.
    • Clean thoroughly underneath the bumper and remove any dirt or debris before reattaching.
    • To reassemble the device, follow these steps in reverse order.
Conclusie
John Harrison
213 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 3-5, Isaacson Fall 2016 Lid van UMass Dartmouth, Team 3-5, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G5
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 343
