Ga door naar hoofdinhoud
GameStop GS3 GameCube Controller joysticks replacement
Wat je nodig hebt
  1. GameStop GS3 GameCube Controller joysticks replacement, Joysticks: stap 1, afbeelding 1 van 2 GameStop GS3 GameCube Controller joysticks replacement, Joysticks: stap 1, afbeelding 2 van 2
    • Loosen and remove the 6 screws located on the back of the controller using your Phillips Screwdriver.
  2. GameStop GS3 GameCube Controller joysticks replacement: stap 2, afbeelding 1 van 1
    • Carefully pry apart the top and bottom covers.
  3. GameStop GS3 GameCube Controller joysticks replacement: stap 3, afbeelding 1 van 3 GameStop GS3 GameCube Controller joysticks replacement: stap 3, afbeelding 2 van 3 GameStop GS3 GameCube Controller joysticks replacement: stap 3, afbeelding 3 van 3
    • After separation, locate the rumble motor that is attached to the bottom cover of the controller.
    • Loosen and remove the 2 screws that are holding the rumble motor in place.
    • Lift and remove the rumble motor from the case.
  4. GameStop GS3 GameCube Controller joysticks replacement: stap 4, afbeelding 1 van 3 GameStop GS3 GameCube Controller joysticks replacement: stap 4, afbeelding 2 van 3 GameStop GS3 GameCube Controller joysticks replacement: stap 4, afbeelding 3 van 3
    • On the top cover of the controller, locate the green portion of the motherboard.
    • Loosen and remove the 1 screw in the upper left side of the green motherboard.
    • Turn the green motherboard over and attached to the motherboard will be the yellow c-stick.
    • Firmly, but carefully, pull the c-stick off, and clean around the area before reattaching or replacing the c-stick.
    • After cleaning or replacing the c-stick, reattach the green motherboard piece to the orange motherboard piece.
  5. GameStop GS3 GameCube Controller joysticks replacement: stap 5, afbeelding 1 van 3 GameStop GS3 GameCube Controller joysticks replacement: stap 5, afbeelding 2 van 3 GameStop GS3 GameCube Controller joysticks replacement: stap 5, afbeelding 3 van 3
    • Finally, loosen and remove the 2 screws located on the orange motherboard.
    • Pull up and remove the motherboard from the top cover. Then turn the motherboard over.
    • Locate the gray joystick that is attached to the left side of the motherboard.
    • Similarly to the yellow c-stick, firmly, but carefully, pull the gray joystick off, and clean around the area before reattaching or replacing the joystick.
Conclusie
Andrew Gonsalves
226 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 3-5, Isaacson Fall 2016 Lid van UMass Dartmouth, Team 3-5, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G5
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 35
Altijd: 1,391
