Ga door naar hoofdinhoud
GameSir T4 Pro Joystick Replacement
Wat je nodig hebt
  1. GameSir T4 Pro Joystick Replacement, Battery: stap 1, afbeelding 1 van 1
    • Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
  2. GameSir T4 Pro Joystick Replacement: stap 2, afbeelding 1 van 1
    • Use your iFixit opening tool to break the seam of the back of your controller.
    • Be careful when pulling apart, as the charging port wires are connected to both sides of the controller.
  3. GameSir T4 Pro Joystick Replacement: stap 3, afbeelding 1 van 1
    • Using the plastic spudger, wiggle the connection out of place.
  4. GameSir T4 Pro Joystick Replacement: stap 4, afbeelding 1 van 1
    • Apply a slow, but consistent pull to the old 600 maH battery.
    • Attach new battery onto the pad.
  5. GameSir T4 Pro Joystick Replacement, Joystick: stap 5, afbeelding 1 van 2 GameSir T4 Pro Joystick Replacement, Joystick: stap 5, afbeelding 2 van 2
    • Disconnect the rumblers from the motherboard
    • Be careful not to pull the wires while disconnecting rumbler
  6. GameSir T4 Pro Joystick Replacement: stap 6, afbeelding 1 van 1
    • Using the screwdriver, remove the 5 mm screws from the motherboard
  7. GameSir T4 Pro Joystick Replacement: stap 7, afbeelding 1 van 2 GameSir T4 Pro Joystick Replacement: stap 7, afbeelding 2 van 2
    • Using the wedge tool, pop the joystick out
  8. GameSir T4 Pro Joystick Replacement: stap 8, afbeelding 1 van 2 GameSir T4 Pro Joystick Replacement: stap 8, afbeelding 2 van 2
    • Make sure the square of the joystick matches the square of the pad and pop it in place.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Madison Puckett
755 Reputatie
5 handleidingen geschreven
3 opmerkingen
I bought ps4 joysticks for the repair, but ps4 joysticks seems larger so it's stuck
Mohamed NACERI - Antwoord
PlayStation4 stick is not compatible with GameSir T4 Pro. The stick for the Nintendo Switch PRO controller does not interfere, but this also requires processing for installation.
NAKIRI - Antwoord
It appears that you will need to remove the light diffuser(white tubular plastic sleeve) from the case to make the parts fit.
NAKIRI -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 34
Afgelopen 30 dagen: 168
Altijd: 3,780
