Ga door naar hoofdinhoud
GameSir T4 Pro Directional Pad Replacement
Wat je nodig hebt
  1. GameSir T4 Pro Directional Pad Replacement, Battery: stap 1, afbeelding 1 van 1
    • Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
  2. GameSir T4 Pro Directional Pad Replacement: stap 2, afbeelding 1 van 1
    • Use your iFixit opening tool to break the seam of the back of your controller.
    • Be careful when pulling apart, as the charging port wires are connected to both sides of the controller.
  3. GameSir T4 Pro Directional Pad Replacement: stap 3, afbeelding 1 van 1
    • Using the plastic spudger, wiggle the connection out of place.
  4. GameSir T4 Pro Directional Pad Replacement: stap 4, afbeelding 1 van 1
    • Apply a slow, but consistent pull to the old 600 maH battery.
    • Attach new battery onto the pad.
  5. GameSir T4 Pro Directional Pad Replacement, Directional Pad: stap 5, afbeelding 1 van 2 GameSir T4 Pro Directional Pad Replacement, Directional Pad: stap 5, afbeelding 2 van 2
    • To get to the directional pad (d-pad), remove the three 5mm screws on the motherboard.
  6. GameSir T4 Pro Directional Pad Replacement: stap 6, afbeelding 1 van 1
    • Disconnect all white connectors from the motherboard.
  7. GameSir T4 Pro Directional Pad Replacement: stap 7, afbeelding 1 van 1
    • Carefully pull the motherboard away to reveal the front panel.
  8. GameSir T4 Pro Directional Pad Replacement: stap 8, afbeelding 1 van 1
    • Remove the d-pad from the front panel.
  9. GameSir T4 Pro Directional Pad Replacement: stap 9, afbeelding 1 van 1
    • Place your new d-pad in place.
Conclusie
Madison Puckett
755 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 30
Altijd: 705
