Ga door naar hoofdinhoud
GameSir T4 Pro Battery Replacement
Wat je nodig hebt
  1. GameSir T4 Pro Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
  2. GameSir T4 Pro Battery Replacement: stap 2, afbeelding 1 van 1
    • Use your iFixit opening tool to break the seam of the back of your controller.
    • Be careful when pulling apart, as the charging port wires are connected to both sides of the controller.
  3. GameSir T4 Pro Battery Replacement: stap 3, afbeelding 1 van 1
    • Using the plastic spudger, wiggle the connection out of place.
  4. GameSir T4 Pro Battery Replacement: stap 4, afbeelding 1 van 1
    • Apply a slow, but consistent pull to the old 600 maH battery.
    • Attach new battery onto the pad.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Madison Puckett
755 Reputatie
5 handleidingen geschreven
3 opmerkingen
Battery Model is pl502450 600mah
3.7v
Eugene Eugenio - Antwoord
Where can I buy this battery? Do You have a link to it?
Roberto Barros -
Roberto Barros - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 78
Altijd: 1,585
