Ga door naar hoofdinhoud
GameSir G7 SE Motherboard Replacement
Wat je nodig hebt
  1. GameSir G7 SE Motherboard Replacement, Interior face plate: stap 1, afbeelding 1 van 1
    • Remove the faceplate by prying upwards with a plastic opening tool.
    • This faceplate is magnetic and will be easy to come off.
    Vraag FixBot
    Voeg opmerking toe
  2. GameSir G7 SE Motherboard Replacement: stap 2, afbeelding 1 van 2 GameSir G7 SE Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Use a T6 Torx Screwdriver to remove the six 9 mm screws from the interior face plate.
    Vraag FixBot
    Voeg opmerking toe
  3. GameSir G7 SE Motherboard Replacement: stap 3, afbeelding 1 van 2 GameSir G7 SE Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Using a plastic spudger tool, remove the interior face plate. Go around all the edges, prying downwards until it's removed.
    • Make sure to hold the controller upside down; otherwise the buttons will fall out.
    Vraag FixBot
    Voeg opmerking toe
  4. GameSir G7 SE Motherboard Replacement, Motherboard: stap 4, afbeelding 1 van 1
    • Use the Phillips #0 screwdriver bit to remove the four 9 mm screws holding the motherboard in place.
    Vraag FixBot
    Voeg opmerking toe
  5. GameSir G7 SE Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Pull straight up on the board to remove the motherboard and connecting components
    • Be careful to not dislodge the back buttons from the back plate housing
    Vraag FixBot
    Voeg opmerking toe
Conclusie
1Gids Commentaar
Hello,where did you find or buy a new motherboard for this?
DavidofSlim7 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 29
Afgelopen 30 dagen: 134
Altijd: 2,935
