Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Use the following guide to replace buttons in the device.
Wat je nodig hebt
Remove the Phillips #00 screw on the side of the Game Boy closest to the directional pad.
Once the screw has been loosened, lift the cover off the back of the device.
Locate the two circular holes on the side of the Game Boy nearest to the directional pad.
Remove the two tri-wing screws on the top of the Game Boy and the two screws next to the volume/contrast switch.
9 andere personen hebben deze handleiding voltooid.
3 opmerkingen
Buenas abra el modo de reparar o puentear la placa de los botones start y selec ya que el flex se rompió
Good open the way to repairing or bypassing the plate and start buttons selec since the flex broke
Any one know the right size shoulder buttons are for replacement ? Are they the same size as a ds lite R and L button ?
