Ga door naar hoofdinhoud
Game Boy Color Screen Cover Replacement
Wat je nodig hebt
  1. Game Boy Color Screen Cover Replacement, Battery: stap 1, afbeelding 1 van 2 Game Boy Color Screen Cover Replacement, Battery: stap 1, afbeelding 2 van 2
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color Screen Cover Replacement: stap 2, afbeelding 1 van 1
    • Remove the batteries from the battery compartment.
  3. Game Boy Color Screen Cover Replacement, Screen Cover: stap 3, afbeelding 1 van 1
    • Carefully slide a razor blade under one of the corners of the screen cover.
  4. Game Boy Color Screen Cover Replacement: stap 4, afbeelding 1 van 1
    • Carefully lift up on the corner of the screen until you can grab the corner with your fingers.
    • Continue gently pulling up on the cover until it is fully removed.
Conclusie
24 andere personen hebben deze handleiding voltooid.
Nick Katsantones
946 Reputatie
4 handleidingen geschreven
Cal Poly, Team 19-47, Regan Winter 2013 Lid van Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
4 Leden
56 handleidingen geschreven
4 opmerkingen
bro, you mustn't to dismount the console to only remove the old lend
sdfsafas - Antwoord
You only need step 7 and 8.
h027299c - Antwoord
An alternative method is to in step 7 insert a small screwdriver into the hole in the front shell where the power light goes through and push off the screen enough to pry it off with your hands. Thereby avoiding this razor-near-the-screen business. You will also most likely need some alcohol (or similar) to loosen the residue leftover from the old screen.
Nick G - Antwoord
Yes that's true! I've seen repair videos where they do it the way you mentioned, much less of a headache
David Hannum -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 33
Afgelopen 30 dagen: 189
Altijd: 22,023
