Ga door naar hoofdinhoud
Inleiding
The LCD Display is the screen that displays images from the Game Boy Color. This guide details how to disassemble and install an LCD Display.
  1. Locate the battery compartment on the back of the Game Boy Color. Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Remove the batteries from the battery compartment.
    • Remove the batteries from the battery compartment.
  3. Using a Y1 screwdriver, remove the six screws on the back of the device as pictured.  The bottom two screws are located inside of the battery compartment.
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
  4. PC Laptop batterijen
    Een snelle fix voor een grote boost.
    Nu winkelen
    Nu winkelen
  5. Gently lift and separate the back housing from the rest of the device.  Now you've got the back housing out! Gently lift and separate the back housing from the rest of the device.  Now you've got the back housing out!
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
  6. Push up on the tabs on either side of the ribbon with a spudger.
    • Push up on the tabs on either side of the ribbon with a spudger.
  7. Gently remove the ribbon cable from the port
    • Gently remove the ribbon cable from the port
  8. Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture. Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
    • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
    It’s not mentioned here, but be sure to unplug the LCD flex cable at the top of the motherboard before removing the motherboard. To do so, gently press the clips on either side of the receptacle toward the top of the Game Boy. When they are both pressed up, the orange cable will slide freely out
    Ben Perkins - Antwoord
    Thanks Ben. That's a very good point. Just ripping it out will cost you a couple bucks, not to mention your Gameboy will not work until you replace that ribbon cable.
    Chris Pavlik - Antwoord
  9. Gently lift the motherboard from the front housing.
    • Gently lift the motherboard from the front housing.
  10. Gently pry and lift the LCD Display from the front panel. Twisting the front casing may help gain more leverage.
    • Gently pry and lift the LCD Display from the front panel.
    • Twisting the front casing may help gain more leverage.
Conclusie
18 andere personen hebben deze handleiding voltooid.
Ajmal Puyehgar
243 Reputatie
1 Handleiding geschreven
Cal Poly, Team 19-47, Regan Winter 2013 Lid van Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
4 Leden
33 handleidingen geschreven
I broke my screen doing this. Be really gentle!
Andrew - Antwoord
Broke my screen just like the last commenter. These instructions are retarded. DON’T pry the screen from the back. Take the front cover off and PUSH it from the front. The circuity for the display is encased in the thin piece of glass all around the LCD. Prying WILL break it!
VoopTech - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 7
Afgelopen 7 Dagen: 63
Afgelopen 30 Dagen: 335
Altijd: 27,357
