Ga door naar hoofdinhoud
Game Boy Color Front Housing Replacement
Wat je nodig hebt
  1. Game Boy Color Front Housing Replacement, Battery: stap 1, afbeelding 1 van 2 Game Boy Color Front Housing Replacement, Battery: stap 1, afbeelding 2 van 2
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color Front Housing Replacement: stap 2, afbeelding 1 van 1
    • Remove the batteries from the battery compartment.
  3. Game Boy Color Front Housing Replacement, Back Housing: stap 3, afbeelding 1 van 1
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
  4. Game Boy Color Front Housing Replacement: stap 4, afbeelding 1 van 2 Game Boy Color Front Housing Replacement: stap 4, afbeelding 2 van 2
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
  5. Game Boy Color Front Housing Replacement, LCD Ribbon Cable: stap 5, afbeelding 1 van 3 Game Boy Color Front Housing Replacement, LCD Ribbon Cable: stap 5, afbeelding 2 van 3 Game Boy Color Front Housing Replacement, LCD Ribbon Cable: stap 5, afbeelding 3 van 3
    • Push up on the tabs on either side of the ribbon with a spudger.
  6. Game Boy Color Front Housing Replacement: stap 6, afbeelding 1 van 2 Game Boy Color Front Housing Replacement: stap 6, afbeelding 2 van 2
    • Gently remove the ribbon cable from the port
  7. Game Boy Color Front Housing Replacement, Motherboard: stap 7, afbeelding 1 van 2 Game Boy Color Front Housing Replacement, Motherboard: stap 7, afbeelding 2 van 2
    • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
  8. Game Boy Color Front Housing Replacement: stap 8, afbeelding 1 van 1
    • Gently lift the motherboard from the front housing.
  9. Game Boy Color Front Housing Replacement, Buttons: stap 9, afbeelding 1 van 1
    • Remove the rubber backing on each button grouping.
  10. Game Boy Color Front Housing Replacement: stap 10, afbeelding 1 van 1
    • Remove the original buttons from the housing.
  11. Game Boy Color Front Housing Replacement, LCD Display: stap 11, afbeelding 1 van 2 Game Boy Color Front Housing Replacement, LCD Display: stap 11, afbeelding 2 van 2
    • Gently pry and lift the LCD Display from the front panel.
    • Twisting the front casing may help gain more leverage.
Conclusie
22 andere personen hebben deze handleiding voltooid.
Angela Yoeurng
1.965 Reputatie
2 handleidingen geschreven
Cal Poly, Team 19-47, Regan Winter 2013 Lid van Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
4 Leden
61 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 33
Afgelopen 30 dagen: 126
Altijd: 12,793
