Ga door naar hoofdinhoud
Game Boy Color Buttons Replacement
Wat je nodig hebt
  1. Game Boy Color Buttons Replacement, Battery: stap 1, afbeelding 1 van 2 Game Boy Color Buttons Replacement, Battery: stap 1, afbeelding 2 van 2
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color Buttons Replacement: stap 2, afbeelding 1 van 1
    • Remove the batteries from the battery compartment.
  3. Game Boy Color Buttons Replacement, Back Housing: stap 3, afbeelding 1 van 1
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
    I did this with a Y0 bit. It works if you are careful. I wouldn't recommend it on other consoles but for this tiny thing, it works.
    phnome - Antwoord
    The guide says a Y0 is needed. Is it a Y1 or Y0?
    Trav - Antwoord
  4. Game Boy Color Buttons Replacement: stap 4, afbeelding 1 van 2 Game Boy Color Buttons Replacement: stap 4, afbeelding 2 van 2
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
  5. Game Boy Color Buttons Replacement, LCD Ribbon Cable: stap 5, afbeelding 1 van 1
    • Push up on the tabs on either side of the ribbon with a spudger.
  6. Game Boy Color Buttons Replacement: stap 6, afbeelding 1 van 1
    • Gently remove the ribbon cable from the port
  7. Game Boy Color Buttons Replacement, Motherboard: stap 7, afbeelding 1 van 2 Game Boy Color Buttons Replacement, Motherboard: stap 7, afbeelding 2 van 2
    • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
    It’s not mentioned here, but be sure to unplug the LCD flex cable at the top of the motherboard before removing the motherboard. To do so, gently press the clips on either side of the receptacle toward the top of the Game Boy. When they are both pressed up, the orange cable will slide freely out
    Ben Perkins - Antwoord
    Thanks Ben. That's a very good point. Just ripping it out will cost you a couple bucks, not to mention your Gameboy will not work until you replace that ribbon cable.
    Chris Pavlik - Antwoord
  8. Game Boy Color Buttons Replacement: stap 8, afbeelding 1 van 1
    • Gently lift the motherboard from the front housing.
  9. Game Boy Color Buttons Replacement, Buttons: stap 9, afbeelding 1 van 1
    • Remove the rubber backing on each button grouping.
  10. Game Boy Color Buttons Replacement: stap 10, afbeelding 1 van 1
    • Remove the original buttons from the housing.
Conclusie
24 andere personen hebben deze handleiding voltooid.
Nick Katsantones
937 Reputatie
4 handleidingen geschreven
Cal Poly, Team 19-47, Regan Winter 2013 Lid van Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
4 Leden
56 handleidingen geschreven
2 opmerkingen
Thank you for your information on repair of my color game boy.
just two things.
1. I had a hard time with the removal of the screws. Any tip on that would be helpful.
2. Where can I purchase replacement parts?
Thanks again for all of your help.
Ray Blasko
raymondblasko - Antwoord
In the tools needed it states Y0 screwdriver, but in step 3 it says Y1 which is not the same. Which one is the correct size?
blogcraft - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 54
Afgelopen 30 dagen: 264
Altijd: 27,585
