Ga door naar hoofdinhoud
Game Boy Color Back Housing Replacement
Wat je nodig hebt
  1. Game Boy Color Back Housing Replacement, Battery: stap 1, afbeelding 1 van 2 Game Boy Color Back Housing Replacement, Battery: stap 1, afbeelding 2 van 2
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color Back Housing Replacement: stap 2, afbeelding 1 van 1
    • Remove the batteries from the battery compartment.
  3. Game Boy Color Back Housing Replacement, Back Housing: stap 3, afbeelding 1 van 1
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
    I did this with a Y0 bit. It works if you are careful. I wouldn't recommend it on other consoles but for this tiny thing, it works.
    phnome - Antwoord
    The guide says a Y0 is needed. Is it a Y1 or Y0?
    Trav - Antwoord
  4. Game Boy Color Back Housing Replacement: stap 4, afbeelding 1 van 2 Game Boy Color Back Housing Replacement: stap 4, afbeelding 2 van 2
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
Conclusie
16 andere personen hebben deze handleiding voltooid.
Angela Yoeurng
1.662 Reputatie
2 handleidingen geschreven
Cal Poly, Team 19-47, Regan Winter 2013 Lid van Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
4 Leden
56 handleidingen geschreven
Één opmerking
Can’t seem to figure out how to remove the battery prongs off the back housing :(
Eddy G - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 31
Afgelopen 30 dagen: 118
Altijd: 8,499
