Ga door naar hoofdinhoud
Game Boy Cartridge Battery Replacement
Wat je nodig hebt
  1. Game Boy Cartridge Battery Replacement, Identification: stap 1, afbeelding 1 van 3 Game Boy Cartridge Battery Replacement, Identification: stap 1, afbeelding 2 van 3 Game Boy Cartridge Battery Replacement, Identification: stap 1, afbeelding 3 van 3
    • The first step is to locate the problem. The Game Boy will give you a message such as this.
    • The battery you will need for this cartridge (an original game Boy game) is a CR2025 3V battery.
  2. Game Boy Cartridge Battery Replacement: stap 2, afbeelding 1 van 3 Game Boy Cartridge Battery Replacement: stap 2, afbeelding 2 van 3 Game Boy Cartridge Battery Replacement: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Get your soldering iron heated, gather your tools, tweezers, and a Steel 3.8mm Screwdriver Security Bit
  3. Game Boy Cartridge Battery Replacement: stap 3, afbeelding 1 van 3 Game Boy Cartridge Battery Replacement: stap 3, afbeelding 2 van 3 Game Boy Cartridge Battery Replacement: stap 3, afbeelding 3 van 3
    • On the back side of the cartridge is a priority security bit and you will have to remove it.
  4. Game Boy Cartridge Battery Replacement: stap 4, afbeelding 1 van 3 Game Boy Cartridge Battery Replacement: stap 4, afbeelding 2 van 3 Game Boy Cartridge Battery Replacement: stap 4, afbeelding 3 van 3
    • Next you will need to slide the front face of the cartridge down to expose the motherboard
    • Remove the board from the plastic housing and clamp it in a vice with alligator clips for stability
  5. Game Boy Cartridge Battery Replacement: stap 5, afbeelding 1 van 3 Game Boy Cartridge Battery Replacement: stap 5, afbeelding 2 van 3 Game Boy Cartridge Battery Replacement: stap 5, afbeelding 3 van 3
    • Use the soldering iron to gently heat the top tab while at the same time using the tweezers to pull the top tab away from the board
    • Then do the same to the bottom tab until the battery is free, be sure no to heat the board too much and only where it is soldered
    • Install the new battery in reverse order heating the solder first then setting the tabs on the hot solder, a little more solder may be needed to hold it in place, once it is cool check that the battery is secure
  6. Game Boy Cartridge Battery Replacement: stap 6, afbeelding 1 van 2 Game Boy Cartridge Battery Replacement: stap 6, afbeelding 2 van 2
    • The final step is to set the board back into the plastic housing slide the cover shut and tighten the screw
Conclusie
21 andere personen hebben deze handleiding voltooid.
Zane Hogue
781 Reputatie
1 Handleiding geschreven
6 opmerkingen
Do you know what battery type is needed for older games like Pokémon Green?
There are no telling marks and it's notably smaller than the battery used for others I've fixed like Crystal or Red. I want to be sure I'm using the right replacement.
jackson3jonathan - Antwoord
The older cartridges should use the CR2025 the gameboy advanced cartridges sometimes use the CR1616, I buy my batteries off of amazon with the soldering tabs on them
Zane Hogue -
When you change a Gameboy Cartridge battery, do you lose the currunt game save , THX
Ken Stock - Antwoord
Yes, anytime power is lost to the volatile memory the save is wiped.
Austin Fischer -
The purpose of the battery in the cartridge is to retain stored memory such as saved games so if you remove the battery for replacement or the battery dies it will delete the saved game. Sucks really hope this helps
Zane Hogue - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 21
Afgelopen 7 dagen: 157
Afgelopen 30 dagen: 759
Altijd: 69,249
