Ga door naar hoofdinhoud
Game Boy Cartridge Battery Replacement
Wat je nodig hebt
  1. Game Boy Cartridge Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Game Boy Cartridge Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Use the screwdriver to loosen the screw on the cartridge.
  2. Game Boy Cartridge Battery Replacement: stap 2, afbeelding 1 van 1
    • Switch on your multimeter and select the Voltage (V) mode. Then, test the voltage of the battery in the cartridge.
  3. Game Boy Cartridge Battery Replacement: stap 3, afbeelding 1 van 1
    • Apply some of the flux paste to help desolder the soldered areas on the battery.
  4. Game Boy Cartridge Battery Replacement: stap 4, afbeelding 1 van 1
    • Be careful when handling a fully heated soldering iron, as it can burn you.
    • Use the soldering iron once it heats up fully. Then, heat up the soldered areas with the iron.
  5. Game Boy Cartridge Battery Replacement: stap 5, afbeelding 1 van 2 Game Boy Cartridge Battery Replacement: stap 5, afbeelding 2 van 2
    • Pick up the solder with the desoldering braid.
  6. Game Boy Cartridge Battery Replacement: stap 6, afbeelding 1 van 1
    • Wipe off any excess flux paste.
    • The flux paste can damage the circuit board if not removed completely or spread to other areas on the circuit board.
  7. Game Boy Cartridge Battery Replacement: stap 7, afbeelding 1 van 2 Game Boy Cartridge Battery Replacement: stap 7, afbeelding 2 van 2
    • Make sure to align the battery's positive side where the positive indicator is and the negative side where the negative indicator is.
    • Use the soldering iron and soldering wire to solder both sides of the battery into place.
  8. Game Boy Cartridge Battery Replacement: stap 8, afbeelding 1 van 1
    • The battery has to have at least 1.5V. If the multimeter reads a negative value, then most likely, the terminals are placed opposite, so switch them around and check the resulting value once more.
  9. Game Boy Cartridge Battery Replacement: stap 9, afbeelding 1 van 2 Game Boy Cartridge Battery Replacement: stap 9, afbeelding 2 van 2
    • Align the cartridge and the circuit board.
    • Then tighten the screw to secure the cartridge into place.
Conclusie
To reassemble your game cartridge, follow step 9.
4 andere personen hebben deze handleiding voltooid.
Jose Ayala
330 Reputatie
1 Handleiding geschreven
CSU Los Angeles, Team 3-1, Briggs Fall 2023 Lid van CSU Los Angeles, Team 3-1, Briggs Fall 2023
CSULA-BRIGGS-F23S3G1
1 Lid
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 69
Afgelopen 30 dagen: 307
Altijd: 4,204
