Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Take the battery cover off by releasing the locking tab and hinging the cover away. Remove the batteries inside the cover
Remove the six back panel screws using a Tri-wing Screwdriver.
Remove bottom back panel screw with a Phillips #1 screw driver. (Image #2)
Remove the back panel by pulling away with one hand and the front secured in the other hand.
Remove left and right triggers by lifting and pulling them away from the system.
Do the same for side panels
Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
Remove the three screws on the circuit board with a Phillips #1 screw driver.
Pull circuit board away from the front panel by pulling up at the bottom of the circuit board, keeping the top ribbon still connected.
4 andere personen hebben deze handleiding voltooid.
