Inleiding
This guide will give step by step instructions on how to remove and replace both speakers in a Samsung Galaxy Tab S 10.5.
Wat je nodig hebt
Place the plastic opening tool into the SD card slot or charge port.
Try in an upward motion until you see a separation between the tablet and back cover.
Starting with the right speaker, remove the 10 mm Phillips #000 screws.
Use the spudger to begin pulling out the speaker.
Wedge the spudger beneath the amplifier to remove it from the adhesive holding it down.
4 andere personen hebben deze handleiding voltooid.
3 opmerkingen
Absolutely right. See my comment above. Carefully prising with the right tools between the display and the frame - the bezel - and working around the outside of the display will eventually cause the bezel to come away from the display with the back cover attached. You can then access the parts you need to get to.
Suggestion….add the necessary step of removing the frame that covers the left speaker. If you follow the instructions in this guide, you will not be able to access and remove the left speaker, which is critical considering the on off and volume switches are integral to the speaker.
