Ga door naar hoofdinhoud
Galaxy Tab S 10.5 Battery Replacement
Wat je nodig hebt
  1. Galaxy Tab S 10.5 Battery Replacement, Disassembling Galaxy Tab S 10.5 Back Cover: stap 1, afbeelding 1 van 2 Galaxy Tab S 10.5 Battery Replacement, Disassembling Galaxy Tab S 10.5 Back Cover: stap 1, afbeelding 2 van 2
    • Place the plastic opening tool into the SD card slot or charge port.
    • Try in an upward motion until you see a separation between the tablet and back cover.
  2. Galaxy Tab S 10.5 Battery Replacement: stap 2, afbeelding 1 van 1
    • Work around the entire device by sliding the plastic opening tool around the rim.
    • If this is the first time, it will be hard to separate the back cover from the tablet.
    • The clips are approximately 5 cm apart. While working around the device, the clips will make a dislocating sound when disconnected.
  3. Galaxy Tab S 10.5 Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove the back cover once all links have been separated.
    • Be careful when touching any of the internal components of the tablet.
  4. Galaxy Tab S 10.5 Battery Replacement, Battery: stap 4, afbeelding 1 van 3 Galaxy Tab S 10.5 Battery Replacement, Battery: stap 4, afbeelding 2 van 3 Galaxy Tab S 10.5 Battery Replacement, Battery: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Using tweezers, peel back the green tape from the ZIF connectors on the two black ribbon cables.
    • Use a plastic opening tool to lift up the plastic clips on the ZIF connectors.
  5. Galaxy Tab S 10.5 Battery Replacement: stap 5, afbeelding 1 van 1
    • Remove the six 2mm screws Phillips #000 screws surrounding the battery.
  6. Galaxy Tab S 10.5 Battery Replacement: stap 6, afbeelding 1 van 3 Galaxy Tab S 10.5 Battery Replacement: stap 6, afbeelding 2 van 3 Galaxy Tab S 10.5 Battery Replacement: stap 6, afbeelding 3 van 3
    • Place the plastic opening tool between the frame and battery.
    • Move the plastic opening tool in a downward motion, away from the battery to bring the battery out of the device.
  7. Galaxy Tab S 10.5 Battery Replacement: stap 7, afbeelding 1 van 3 Galaxy Tab S 10.5 Battery Replacement: stap 7, afbeelding 2 van 3 Galaxy Tab S 10.5 Battery Replacement: stap 7, afbeelding 3 van 3
    • Hold the battery and disconnect the plug to remove the battery.
Conclusie
83 andere personen hebben deze handleiding voltooid.
Jordan Soto
3.276 Reputatie
6 handleidingen geschreven
USF Tampa, Team 3-2, Eyestone Fall 2015 Lid van USF Tampa, Team 3-2, Eyestone Fall 2015
USFT-EYESTONE-F15S3G2
3 Leden
20 handleidingen geschreven
20 opmerkingen
where is a good place to buy a replacement battery?
brianference - Antwoord
Artículo muy positivo: pasos muy bien detallados. Me ha resultado fácil la el cambio de batería. Gracias por tu colaboración.
Miguel Ángel - Antwoord
Bought mine off of ebay
Jerry Belschner - Antwoord
Great guide! Thanks a lot!
Markus - Antwoord
I bought a battery but am afraid to do the replacement myself. Where can I take the tablet to have it done?
Barb - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 62
Afgelopen 30 dagen: 278
Altijd: 101,362
