Inleiding
If the device does not charge, the problem is with:
- Charging board
- Main flex cable
- Motherboard
In this manual, we will show you how to fix your device if the problem is with the Motherboard FPC connector.
Wat je nodig hebt
Video overzicht
Samsung Galaxy A71 does not charge.
Connect the charger and press the phone as per the second image.
Warm the device to soften the adhesive.
Use plastic tools and isopropyl alcohol to separate the back cover.
Remove all silver Phillips screws.
Remove the SIM Tray.
Use a suitable plastic tool to remove the middle frame.
7 andere personen hebben deze handleiding voltooid.
