Ga door naar hoofdinhoud
GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair
Wat je nodig hebt
  1. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair, GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: stap 1, afbeelding 1 van 2 GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair, GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: stap 1, afbeelding 2 van 2
    • Take out the front metal grill.
    • By the side of the cover, there's a metal piece you have to flick open to get the front and back unlocked from each other.
  2. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: stap 2, afbeelding 1 van 2 GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: stap 2, afbeelding 2 van 2
    • Turn the knob to take out the blade cap.
    • Spin the knob counterclockwise. This way, you are loosening the knob.
  3. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: stap 3, afbeelding 1 van 2 GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: stap 3, afbeelding 2 van 2
    • Loosen the plastic nut on the rear grille in order to take the rear grille out.
  4. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: stap 4, afbeelding 1 van 2 GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: stap 4, afbeelding 2 van 2
    • Unscrew the plastic on the fan motor, and gently pull the slide open: There are four screws, proceed to taking off the plastic plates.
  5. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: stap 5, afbeelding 1 van 2 GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: stap 5, afbeelding 2 van 2
    • Apply machine oil onto the rusted parts.
    • Take the machine oil and make sure you apply the oil to the around fan rotor
    • Let the oil stay for about 5 minutes
    • Do not spill the oil on the surface or let the oil go into the rotor.
  6. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: stap 6, afbeelding 1 van 2 GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: stap 6, afbeelding 2 van 2
    • Carefully place the plastic plate properly on the surface of the fan rotor.
    • Make sure the screws align with the holes on the fan motor, then proceed to screw.
  7. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: stap 7, afbeelding 1 van 1
    • Place back the fan rear grill, pick up the plastic grill nut.
    • fit in the hole and screw down the fan rear grill upon the fan motor.
  8. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: stap 8, afbeelding 1 van 1
    • Place the blade right back into the motor pin.
    • Take the blade, make sure the blade sit on the fan edges.
  9. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: stap 9, afbeelding 1 van 1
    • Take the circlip, spin the circlip right on the blade, ensure it is tight.
  10. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: stap 10, afbeelding 1 van 1
    • Pick up the front grille, ensure the grille aligns with the metal piece around the fan.
    • Then lock the metal piece, this way the front and the rear grilles are locked.
    • If the metal piece do not align, you would have issues locking the grilles to each other.
Conclusie
TUOYO FABIYI
238 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 48
Altijd: 418
