Ga door naar hoofdinhoud
GPD WIN Silicon Pad Replacement
Wat je nodig hebt
  1. GPD WIN Silicon Pad Replacement, Remove the screw of the case: stap 1, afbeelding 1 van 2 GPD WIN Silicon Pad Replacement, Remove the screw of the case: stap 1, afbeelding 2 van 2
    • Remove the case screws
  2. GPD WIN Silicon Pad Replacement, Remove case: stap 2, afbeelding 1 van 3 GPD WIN Silicon Pad Replacement, Remove case: stap 2, afbeelding 2 van 3 GPD WIN Silicon Pad Replacement, Remove case: stap 2, afbeelding 3 van 3
    • There is a small space beside the keyboard, insert the pick and remove the claw
    • As you open the device, you can see that the flexible cable and the battery cable are connected. Then unplug the connector.
  3. GPD WIN Silicon Pad Replacement, Remove screws on the logic board: stap 3, afbeelding 1 van 2 GPD WIN Silicon Pad Replacement, Remove screws on the logic board: stap 3, afbeelding 2 van 2
    • Remove screws on the logic board.
    • Because some black threads are mixed, do not forget to remove
  4. GPD WIN Silicon Pad Replacement, Remove the wifi connector on the logic board: stap 4, afbeelding 1 van 2 GPD WIN Silicon Pad Replacement, Remove the wifi connector on the logic board: stap 4, afbeelding 2 van 2
    • Remove Wi-Fi antenna cable and LCD connector
  5. GPD WIN Silicon Pad Replacement, Remove the joystick: stap 5, afbeelding 1 van 2 GPD WIN Silicon Pad Replacement, Remove the joystick: stap 5, afbeelding 2 van 2
    • Remove the screws of the joystick and remove the flex cable from the connector.
    • Then, it is ready to pull logic board out of the case.
  6. GPD WIN Silicon Pad Replacement, Replace the silicone pad: stap 6, afbeelding 1 van 2 GPD WIN Silicon Pad Replacement, Replace the silicone pad: stap 6, afbeelding 2 van 2
    • You can access the silicone pad by removing the logic board.
    • Replace a sticky silicon pad
Conclusie
To reassemble your device, please follow these steps in reverse order.
Één andere persoon heeft deze handleiding voltooid.
Met dank aan deze vertalers:
jp en
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
noria901
482 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 134
Altijd: 2,098
