Ga door naar hoofdinhoud
GMMK-BRN Keyboard Switch Replacement
Wat je nodig hebt
  1. GMMK-BRN Keyboard Switch Replacement, Keyboard Switch: stap 1, afbeelding 1 van 2 GMMK-BRN Keyboard Switch Replacement, Keyboard Switch: stap 1, afbeelding 2 van 2
    • Unplug the keyboard from your device.
    • Place the keyboard on a clean workspace, along with the tools required.
  2. GMMK-BRN Keyboard Switch Replacement: stap 2, afbeelding 1 van 3 GMMK-BRN Keyboard Switch Replacement: stap 2, afbeelding 2 van 3 GMMK-BRN Keyboard Switch Replacement: stap 2, afbeelding 3 van 3
    • Use your fingers or a keycap remover and pull directly upward to remove the keycap.
    • It is possible to damage the keycap if not pulled directly upwards.
  3. GMMK-BRN Keyboard Switch Replacement: stap 3, afbeelding 1 van 2 GMMK-BRN Keyboard Switch Replacement: stap 3, afbeelding 2 van 2
    • Use the switch remover to push the tabs in on the opposite sides of the switch.
    • Firmly pull the switch upwards.
    • If the switch is pulled at an angle, there is a risk to damaging the switch.
    • The switch may not come out easily, so more force may be required.
  4. GMMK-BRN Keyboard Switch Replacement: stap 4, afbeelding 1 van 3 GMMK-BRN Keyboard Switch Replacement: stap 4, afbeelding 2 van 3 GMMK-BRN Keyboard Switch Replacement: stap 4, afbeelding 3 van 3
    • Align the pins on the keycap with the ones inside the keyboard.
    • Insert the switch, and press down firmly until a click is heard.
  5. GMMK-BRN Keyboard Switch Replacement: stap 5, afbeelding 1 van 3 GMMK-BRN Keyboard Switch Replacement: stap 5, afbeelding 2 van 3 GMMK-BRN Keyboard Switch Replacement: stap 5, afbeelding 3 van 3
    • Align the cross of the keycap with the cross of the switch.
    • Push the keycap down firmly to reattach.
  6. GMMK-BRN Keyboard Switch Replacement: stap 6, afbeelding 1 van 2 GMMK-BRN Keyboard Switch Replacement: stap 6, afbeelding 2 van 2
    • Plug the keyboard back into your device.
    • Turn you device on and do a test to see if the new switch works.
Conclusie
Kyle Lieu Dang
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 20
Altijd: 303
