Ga door naar hoofdinhoud
GE TrueTemp Oven Light Bulb Replacement
Wat je nodig hebt
  1. GE TrueTemp Oven Light Bulb Replacement, Light Bulb: stap 1, afbeelding 1 van 1
    • Unplug the power cord from the wall outlet for safety purposes.
  2. GE TrueTemp Oven Light Bulb Replacement: stap 2, afbeelding 1 van 1
    • Open the oven door and locate the oven light placement (located on the back wall, in upper left corner for this specific model.)
  3. GE TrueTemp Oven Light Bulb Replacement: stap 3, afbeelding 1 van 1
    • Locate the metal strap holding the glass cover over the bulb.
  4. GE TrueTemp Oven Light Bulb Replacement: stap 4, afbeelding 1 van 1
    • Slide the strap to the side to free the glass casing.
  5. GE TrueTemp Oven Light Bulb Replacement: stap 5, afbeelding 1 van 1
    • View the light bulb without the glass case and ensure there is nothing else securing it to the oven.
    • Check to make sure there is no debris around the bulb and that the light bulb is ready to be removed.
  6. GE TrueTemp Oven Light Bulb Replacement: stap 6, afbeelding 1 van 1
    • Using a dry cloth or gloves, unscrew the light bulb by turning it in a counter clockwise motion.
  7. GE TrueTemp Oven Light Bulb Replacement: stap 7, afbeelding 1 van 2 GE TrueTemp Oven Light Bulb Replacement: stap 7, afbeelding 2 van 2
    • Screw in new light bulb in the clock wise direction.
  8. GE TrueTemp Oven Light Bulb Replacement: stap 8, afbeelding 1 van 1
    • Replace the glass cover over the bulb, but be sure to hold on to it tightly.
  9. GE TrueTemp Oven Light Bulb Replacement: stap 9, afbeelding 1 van 1
    • Secure the glass case to the oven with the metal strap by sliding it back over case until it fits tightly.
  10. GE TrueTemp Oven Light Bulb Replacement: stap 10, afbeelding 1 van 1
    • Plug the oven power cord back into power source.
  11. GE TrueTemp Oven Light Bulb Replacement: stap 11, afbeelding 1 van 1
    • Press the button for oven light to come on.
  12. GE TrueTemp Oven Light Bulb Replacement: stap 12, afbeelding 1 van 1
    • View light to ensure the replacement was successful.
Eindstreep
Samantha Connell
214 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 79
Afgelopen 30 dagen: 388
Altijd: 12,626
