Ga door naar hoofdinhoud
GE Carescape R860 Air Filter Cleaning
Medische apparatuur
Noch iFixit, noch deze reparatiehandleiding worden onderschreven door of zijn gelieerd aan de fabrikant van de desbetreffende medische apparatuur.
Wat je nodig hebt
  1. GE Carescape R860 Air Filter Cleaning, Air Filter: stap 1, afbeelding 1 van 1
    • Disconnect the pipeline sources from the wall.
    • These are the yellow and green hoses, the air and oxygen hoses, in the image.
  2. GE Carescape R860 Air Filter Cleaning: stap 2, afbeelding 1 van 2 GE Carescape R860 Air Filter Cleaning: stap 2, afbeelding 2 van 2
    • Disconnect the oxygen hose from the machine.
    • This also includes the removal of the oxygen fitting.
  3. GE Carescape R860 Air Filter Cleaning: stap 3, afbeelding 1 van 2 GE Carescape R860 Air Filter Cleaning: stap 3, afbeelding 2 van 2
    • After the oxygen hose has been disconnected, the air hose will be disconnected as well.
    • The air line may have a compressor hose, like this unit, which will need to be removed before the air fitting can be removed.
    • Once this is done, you can look through both openings with a flashlight for debris. If there is debris, move onto the next step. Otherwise, you should reinstall the hoses to the machine and the wall
    • Open both shut-off valves.
    • Verify that the inspiratory outlet is open to atmosphere (not plugged).
    • On the VCB screen:
    • Verify that the Air and O2 Flow Valves are energized ().
    • Set the Air DAC counts to 60,000 (fully open).
    • Set the O2 DAC counts to 60,000 (fully open).
    • After 20 seconds:
    • Close both shut-off valves. Pulse the Air and O2 flow valves 5 times for 5 seconds.
    • Set the Air DAC counts to zero (closed).
    • Set the O2 DAC counts to zero (closed).
    • Note: Closing the shut-off valves before setting the flow DAC counts to zero, bleeds pressure from the system.
Conclusie
Tessa Luzuriaga
171 Reputatie
1 Handleiding geschreven
Cal Poly, Team S7-G9, Paton Spring 2020 Lid van Cal Poly, Team S7-G9, Paton Spring 2020
CPSU-PATON-S20S7G9
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 316
