Ga door naar hoofdinhoud
GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement
Wat je nodig hebt
  1. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery Compartment Cover: stap 1, afbeelding 1 van 3 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery Compartment Cover: stap 1, afbeelding 2 van 3 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery Compartment Cover: stap 1, afbeelding 3 van 3
    • Find the battery compartment on the bottom of the clock radio.
    • Using your thumb, push the compartment cover latch toward the battery.
    • With the latch pushed in, pull the compartment cover upward to remove it..
  2. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery: stap 2, afbeelding 1 van 2 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery: stap 2, afbeelding 2 van 2
    • Lift the battery from the compartment.
    • Pull the battery up and gently disconnect it from the battery connector.
  3. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Screws: stap 3, afbeelding 1 van 2 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Screws: stap 3, afbeelding 2 van 2
    • Using a Phillips #00 Screwdriver, unscrew the six 12mm screws from around the bottom of the clock radio.
  4. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, LCD Cover: stap 4, afbeelding 1 van 1
    • Gently pull the liquid crystal display (LCD) cover off.
  5. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Clock Radio: stap 5, afbeelding 1 van 2 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Clock Radio: stap 5, afbeelding 2 van 2
    • Lift the top off. Two gray, plastic internal pieces will fall out when you do this; set them aside.
Conclusie
Dominick Giguere
848 Reputatie
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 351
