Wat je nodig hebt
Remove the 4 small foam piece on the back casing of the device using a metal tweezers. After remove the 4 screws under the foam piece using a Phillips screwdriver (#size)
Carefully separate the device's front outer casing from the back outer casing.
The microphone will still be on the front casing while connected on the main board on the back casing. Softly using your finger pull the microphone out of the casing.
The speaker will be glued to the front casing. To remove the glue use a metal spudger or use a heat gun to head the glue and remove the speaker.
Remove the 3 screw that holds the main board to the back casing using Phillips head #2 screwdriver.
After lift the main board from the back outer casing using a plastic opener tool.
The Speaker is connected of the main board of the device with two color coded wires.
Before Taking apart the speaker you must take out the soldering wire on back of the main board. After removing it you can install the new speakers.
