Ga door naar hoofdinhoud
GARDENA Smart Gateway Repair
Wat je nodig hebt
  1. GARDENA Smart Gateway Repair, Open device: stap 1, afbeelding 1 van 2 GARDENA Smart Gateway Repair, Open device: stap 1, afbeelding 2 van 2
    • Remove the rubber feet. Below are four Torx T9 screws.
  2. GARDENA Smart Gateway Repair, Fuse: stap 2, afbeelding 1 van 1
    • Identify if the fuse is blown. Take a multimeter and measure the resistance. There should be no measurable resistance.
    • If the fuse is defective it should be replaced with a new one. Component listed under parts.
  3. GARDENA Smart Gateway Repair, TVS Diode: stap 3, afbeelding 1 van 1
    • Second component likely to fail is the TVS Diode (Transient-voltage-suppression diode). It is used to protect the sensitive circuit from overvoltage.
    • Measure the resistance on the two terminals. Resistance should be infinite.
    • If component is broken the circuit is shorted. Therefore the component can be removed in order to repair the device. Afterwards the circuit is not protected against overvoltage anymore!
  4. GARDENA Smart Gateway Repair, Test the device: stap 4, afbeelding 1 van 1
    • Power LED should light up green
Conclusie
Computerix
374 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 41
Altijd: 684
