Wat je nodig hebt
Gereedschap gebruikt in deze stap:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Use a 2.5 mm Flathead screwdriver to remove the four 5 mm screws from the bottom of the Furbo.
Use a 2.5 mm Flathead screwdriver to remove the single 5 mm screw under the silver sticker.
Use a Phillips #000 screwdriver to remove the two 5 mm screws from the USB power jack.
Bijna klaar!
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
