Ga door naar hoofdinhoud
Fujtsu Lifebook Model A6110 Battery Replacement
  1. Fujtsu Lifebook Model A6110 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Fujtsu Lifebook Model A6110 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • The computer should be fully turned off and disconnected from the power source.
    • Before handling electronic components, you should ground yourself. This will prevent damage to the components from a static charge. You can do this by touching any metal object.
    • Flip your laptop so that the bottom of the laptop is facing up and the hinges of the screen are closest to you.
  2. Fujtsu Lifebook Model A6110 Battery Replacement: stap 2, afbeelding 1 van 1
    • To remove the battery, place your fingers underneath the two clips and simultaneously lift them up while pulling the cover towards you.
Conclusie
Alvin Thamrin
132 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 3-2, Isaacson Fall 2016 Lid van UMass Dartmouth, Team 3-2, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G2
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 453
