Ga door naar hoofdinhoud
Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement
Wat je nodig hebt
  1. Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 1
    • Turn the laptop over so that the bottom of the laptop faces you.
  2. Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: stap 2, afbeelding 1 van 2 Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Locate the hard drive cover and remove the screw.
  3. Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: stap 3, afbeelding 1 van 2 Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: stap 3, afbeelding 2 van 2
    • Now you can use your finger to pull the cover off.
  4. Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: stap 4, afbeelding 1 van 3 Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: stap 4, afbeelding 2 van 3 Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: stap 4, afbeelding 3 van 3
    • Pull on the pull tab to release the hard drive.
    • Now you can take the hard drive out of the laptop.
  5. Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: stap 5, afbeelding 1 van 3 Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: stap 5, afbeelding 2 van 3 Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: stap 5, afbeelding 3 van 3
    • There is a screw on each corner of the hard drive bracket. To take the hard drive out of its bracket you need to remove the 4 screws.
    • Do not take the screws out of the hard drive itself, only from the bracket.
    • With the screws removed the drive slides out of the bracket.
    • Now you can replace the hard drive with a new one.
Conclusie
5 andere personen hebben deze handleiding voltooid.
storm
552 Reputatie
2 handleidingen geschreven
2 opmerkingen
Please I need a password protection my computer is locked I need a code to unlock my computer pls Esprimo mobile V5515 please help me
sadik G Ibrahim - Antwoord
Is it a Windows password or a BIOS password?
storm -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 41
Altijd: 6,007
