Ga door naar hoofdinhoud
Fujitsu Siemens Amilo Pro Keyboard Replacement
Wat je nodig hebt
  1. Fujitsu Siemens Amilo Pro Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Remove AC adapter and battery.
    • Battery: pull the latch with a battery symbol beside it.
  2. Fujitsu Siemens Amilo Pro Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Use a flat head screwdriver to pry out the hinge cover.
    • (Caution do not pull to hard as this could snap the plastic!)
  3. Fujitsu Siemens Amilo Pro Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Remove the one screw holding in the keyboard.
  4. Fujitsu Siemens Amilo Pro Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Pull the keyboard up towards you.
  5. Fujitsu Siemens Amilo Pro Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Pull the ribbon cable and the keyboard will come out.
    • (Caution this ribbon is very delicate)
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jeremy Scalpello
282 Reputatie
1 Handleiding geschreven
Één opmerking
try to focus the image while taking the picture so people can understand better were to touch
storm builder - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 35
Altijd: 15,558
