Ga door naar hoofdinhoud
Fujitsu Lifebook a6110 Fan Replacement
Wat je nodig hebt
  1. Fujitsu Lifebook a6110 Fan Replacement, Battery: stap 1, afbeelding 1 van 2 Fujitsu Lifebook a6110 Fan Replacement, Battery: stap 1, afbeelding 2 van 2
    • The computer should be fully turned off and disconnected from the power source.
    • Before handling electronic components, you should ground yourself. This will prevent damage to the components from a static charge. You can do this by touching any metal object.
    • Flip your laptop so that the bottom of the laptop is facing up and the hinges of the screen are closest to you.
  2. Fujitsu Lifebook a6110 Fan Replacement: stap 2, afbeelding 1 van 1
    • To remove the battery, place your fingers underneath the two clips and simultaneously lift them up while pulling the cover towards you.
  3. Fujitsu Lifebook a6110 Fan Replacement, Keyboard: stap 3, afbeelding 1 van 3 Fujitsu Lifebook a6110 Fan Replacement, Keyboard: stap 3, afbeelding 2 van 3 Fujitsu Lifebook a6110 Fan Replacement, Keyboard: stap 3, afbeelding 3 van 3
    • Position the laptop like you would if you were to use it. Open the screen to a 180 degrees angle. The screen and the keyboard needs to face up before proceeding.
    • Using a flat edge of the plastic spudger, gently lift the piece of plastic located in the red square. Carefully insert the spudger between the inner edge marked by the arrow.
  4. Fujitsu Lifebook a6110 Fan Replacement: stap 4, afbeelding 1 van 3 Fujitsu Lifebook a6110 Fan Replacement: stap 4, afbeelding 2 van 3 Fujitsu Lifebook a6110 Fan Replacement: stap 4, afbeelding 3 van 3
    • With a Phillips #1 screwdriver, unscrew the four-six mm screws that were hidden under the plastic piece you removed.
  5. Fujitsu Lifebook a6110 Fan Replacement: stap 5, afbeelding 1 van 3 Fujitsu Lifebook a6110 Fan Replacement: stap 5, afbeelding 2 van 3 Fujitsu Lifebook a6110 Fan Replacement: stap 5, afbeelding 3 van 3
    • Lift up on the inner edges of the hinges for the screen. This will detach the face-plate from the computer. Use a spudger to make this process easier.
    • There is a ribbon underneath this panel that attaches to the motherboard. Be careful to not rip this ribbon.
    • The ribbon is located in the top left-hand corner and needs to carefully disconnected from the motherboard, as shown in the next step.
  6. Fujitsu Lifebook a6110 Fan Replacement: stap 6, afbeelding 1 van 2 Fujitsu Lifebook a6110 Fan Replacement: stap 6, afbeelding 2 van 2
    • Detach the ribbon from the motherboard, which will allow you to finish removing the face-plate from the computer.
    • To detach the ribbon, grip the ribbon at the base that is attached to the motherboard, which is the large green circuit-board in the body of the computer.
    • When reassembling the computer, make sure to reconnect the ribbons.
  7. Fujitsu Lifebook a6110 Fan Replacement: stap 7, afbeelding 1 van 2 Fujitsu Lifebook a6110 Fan Replacement: stap 7, afbeelding 2 van 2
    • There is another ribbon connecting the keyboard to the motherboard. Be careful not to rip it
    • The keyboard is now free. Lift up on the keyboard.
  8. Fujitsu Lifebook a6110 Fan Replacement: stap 8, afbeelding 1 van 1
    • This ribbon may be difficult to remove, so be careful in pulling it. You could accidentally break it.
    • Detatch the ribbon from the motherboard
    • When reassembling the computer, make sure to reconnect this ribbon.
  9. Fujitsu Lifebook a6110 Fan Replacement, Fan: stap 9, afbeelding 1 van 1
    • Close the screen of the laptop, then flip the computer over so that the bottom side is facing up.
  10. Fujitsu Lifebook a6110 Fan Replacement: stap 10, afbeelding 1 van 1
    • Using a Phillips #1 screwdriver, remove the eleven 1 cm screws located around the perimeter of the laptop's edge.
  11. Fujitsu Lifebook a6110 Fan Replacement: stap 11, afbeelding 1 van 1
    • Flip the computer over again, like it was before removing the screws. The screen must be opened and pushed down so that it lies flat with the keyboard. Both the keyboard and screen must face up.
  12. Fujitsu Lifebook a6110 Fan Replacement: stap 12, afbeelding 1 van 2 Fujitsu Lifebook a6110 Fan Replacement: stap 12, afbeelding 2 van 2
    • Using a Phillips #1 screwdriver, remove the six 6 mm screws located on the top right and top left corners of the laptop.
    • Using a Phillips #1 screwdriver, remove the four 6 mm screws located around the motherboard.
  13. Fujitsu Lifebook a6110 Fan Replacement: stap 13, afbeelding 1 van 3 Fujitsu Lifebook a6110 Fan Replacement: stap 13, afbeelding 2 van 3 Fujitsu Lifebook a6110 Fan Replacement: stap 13, afbeelding 3 van 3
    • You will notice a cluster of wires at the top left-hand corner of where the keyboard used to be.
    • Carefully detach all wires that are grouped together from the motherboard using either your hands or a spudger.
  14. Fujitsu Lifebook a6110 Fan Replacement: stap 14, afbeelding 1 van 2 Fujitsu Lifebook a6110 Fan Replacement: stap 14, afbeelding 2 van 2
    • To remove the metal undercarriage of the keyboard, you must first detach the ribbon cable connected to the trackpad. Firmly grasp the base of the ribbon cable where it connects to the motherboard and gently pull it upward to disconnect it.
    • Be mindful to not tear the ribbon. It is not delicate but it can still be torn if tugged on too abruptly.
  15. Fujitsu Lifebook a6110 Fan Replacement: stap 15, afbeelding 1 van 3 Fujitsu Lifebook a6110 Fan Replacement: stap 15, afbeelding 2 van 3 Fujitsu Lifebook a6110 Fan Replacement: stap 15, afbeelding 3 van 3
    • Located around the fan, there are two-three mm screws that need to be removed. Use a Phillips #1 screwdriver to turn these screws counter-clockwise and unscrew them.
  16. Fujitsu Lifebook a6110 Fan Replacement: stap 16, afbeelding 1 van 1
    • The fan is now held in place by a wire, and a piece of anti-static tape.
    • Remove the wire by pulling it from the motherboard, using either your hands or a spudger.
    • The tape can simply be peeled away.
Conclusie
Cody Moniz
416 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 3-2, Isaacson Fall 2016 Lid van UMass Dartmouth, Team 3-2, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G2
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 665
