Inleiding
This guide allows the user to access and replace the MicroSD card of a Fujitsu Lifebook Stylistic Q584.
Wat je nodig hebt
Remove the white sticker covering the screws (if applicable).
Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
Remove the ten 3mm screws with a PH00 screwdriver from the shield.
After removing the motherboard, use an ESD-safe spudger to pry up the MicroSD card from the slot.
Gently separate the MicroSD card from the device.
