Inleiding
If you need to replace the camera this guide will provide step-by-step instructions on how to disassemble and replace your camera.
Wat je nodig hebt
Remove the white sticker covering the screws (if applicable).
Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
Remove the ten 3mm screws with a PH00 screwdriver from the shield.
Bijna klaar!
Conclusie
