Inleiding
If you need to replace your Battery for the Fujitsu Lifebook Stylistic Q584 this guide will provide step-by-step instructions. In addition, it's important to remove the battery prior to replacing parts.
Wat je nodig hebt
Remove the white sticker covering the screws (if applicable).
Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
Remove the ten 3mm screws with a PH00 screwdriver from the shield.
Één andere persoon heeft deze handleiding voltooid.
