Inleiding
If your computer is completely unresponsive and the motherboard needs to be replaced or repaired, this guide will show you how to remove the motherboard from the Fujitsu Lifebook S6120.
Wat je nodig hebt
Push the two tabs in towards the laptop.
Lift the battery up and out from the frame of the laptop.
Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
Use a Philips head #0 to remove the 5mm screws.
Use a Philips head #00 to remove the 4mm screws.
