Inleiding
Hello!
In this guide I will show you step by step how to remove RAM Modules from Fujitsu Lifebook E556 Laptop.
Wat je nodig hebt
Remove battery:
1. Pull down and hold that little tab.
2. Move left that slider.
3. Pull up to remove battery from laptop.
To remove RAM cover, you need to:
1. Remove screw holding that cover.
2. Pull up the cover by notch visible right next to screw hole.
To remove RAM modules, simlpy pull away tabs marked by white ovals.
RAM module should pop-up and it'll be possible to pull it out.
