Inleiding
Hello!
In this guide I will show you how to remove HDD or SSD in Fujitsu Lifebook E556 laptop!
Wat je nodig hebt
Remove battery:
1. Pull down and hold that little tab.
2. Move left that slider.
3. Pull up to remove battery from laptop.
Gereedschap gebruikt in deze stap:Plastic Cards$2.99
To remove HDD/SSD cover, you need to:
1. Remove screw holding cover.
2. Pull up the cover by notch visible right next to screw hole. If difficult to pull by finger, use a plastic card or guitar pick.
To remove HDD/SSD, you need to pull disk outwards of connector.
When disconnected, pull up the disk away from bay.
Important! If you wanna place a new disk, make sure it is SLIM format. It is standard for 2,5" SSDs, so nothing to worry about.
2,5" HDDs were made in 2 different thicknesses: standard (9mm) and slim (7mm)
Mine laptop is lacking two rubber bands, that are holding disk. They're not a necessity, cover has some thick rubber on it too, so disk should stay in place.
