Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Locate the two clips on the bottom of the computer that support the battery.
Using your fingers, push the clips inward and then upward.
Lift the battery out of the computer.
Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
Lay the computer flat on a stable surface with the monitor pointing away from you.
Lift the hinge cover enough to expose the ribbon cable.
Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
Lift the keyboard enough to expose the ribbon cable.
Use a spudger to release the ribbon cable from the motherboard.
After the ribbon has been detached, carefully remove the keyboard.
Remove the following screws, all labeled "3."
Two 8.63mm screws.
One 7.65mm screw.
One 5.74mm screw.
Remove the following screw, labeled "15."
One 17.81mm screw.
Remove the screws from the bottom of the hinge as shown in the image.
Use a spudger to detach and remove cables from the motherboard.
Unplug highlighted cables from the wireless module.
Hold down the body of the computer by placing your hands in the pictured positions. Then, lift the display from the body.
