Inleiding
Following these steps, you can effectively replace your display.
Wat je nodig hebt
Locate the two clips on the bottom of the computer that support the battery.
Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
Remove the following screws, all labeled "3."
Two 8.63mm screws.
One 7.65mm screw.
One 5.74mm screw.
Remove the following screw, labeled "15."
One 17.81mm screw.
